G
gvdv
Member
Hi,
I have been transferring some old demos from cassette to digital format, and find that I need to clean the heads and transport mechanism of my cassette deck but no longer have any tape head cleaner.
Does anyone know where I can locate good tape head cleaner, preferrably in Toronto, Canada?
I have read and heard totally contrary opinions about using Isopropyl alcohol, so would appreciate any comments and advice that people have about this. For example, the person here
http://www.kvglabs.com/PDF/cleaning_and_demagnetizing.pdf advises avoiding anything but 99% Isopropyl alcohol, and recommends American Recorder S-721H Head/Pinch Roller Cleaner, and says that the use of Xylene is O.K..
On the other hand, the person here Cleaning and Demagnetizing says that 91% Isopropyl alcohol and denatured alcohol are fine to use.
In the past, I have used denatured alcohol, but would like to use what is best.
I found the American Recorder S-721H Head/Pinch Roller Cleaner here, https://www.americanrecorder.com/detail.php?id=941&search=tape%20head%20cleaner&start_pos=10.
I also notice that the American Recorders site has those cassette head cleaners (in the form of a cassette), but I thought that that type of cleaner could actually damage cassette decks because it is a relatively 'rough' method of cleaning.
I also found a couple of bottles of Rubber Renue http://www.mgchemicals.com/products/408a.html, for cleaning the rubber rollers, that I don't think that I ever used - I'm a bit put off by the fact that it says on the bottle that R.R. contains poison, and that one should not get it on one's skin. Does anyone know if it is safe to use this?
Thanks,
GVDV.
Thanks,
GVDV.
