T
tylerxxx
is it possible to take just the vocal track off of an already mixed song, to mix it with another song? if so, how do i go about doing it?
chessrock said:It's certainly possible.
You'd have to get a hold of the original sessions to do it.
Which might prove tricky on many fronts. Could be costly, time-consuming, etc. involving covert operations, or simply going through traditional licensing channels which would no doubt be quite expensive.
If I'm not mistaken, aren't the bass, kick drum and snare usually panned down the middle as well? I have a vocal remover on my Roland VM-3100 Pro but it really sucks the bass out of the track.SouthSIDE Glen said:If the vocals are coming down the center of the pan space, they can be mostly removed, though how cleanly depends on the recording. There are devices and plugins for removing vocals under such circumstances. A quick Internet search should yield one or two results.
An alternative would be to do it manually. By coincidence, Tom V. at Mastering House just a week ago or so was kind enough to describe a technique in this forum for manually decoding a stereo signal into "mid" and "side" channels using standard multitrack editing software. Take a look in the "DIY Clinic #1" thread for more info on this. Using this method it shuld be possible to partially or fully isolate vocals that are riding right down the center of the stereo mix and remove them with as little harm to the rest of the signal as possible.
G.
Yes they often are. Hence my opening sentence with two caveats included:trabalais said:If I'm not mistaken, aren't the bass, kick drum and snare usually panned down the middle as well?
