WhiteStrat
Don't stare at the eye.
Does anyone know if the preamps in the Symetrix 302 (the half rack space dual pre) are the same as the preamp in the 528e Voice Processor?
Thanks!
Thanks!
Alright...now your "basically" is nagging at me. Is there a difference? I really like the 528e--it's the best in my budget rig on my acoustic guitar among other things.
But I certainly don't need the voice symmetry gizmo, and I can live without the comp & eq.
So to get a couple more channels of the same sound, a 302 should deliver, huh?
Well ... one of them is incorporated in to a channel strip with a bunch of other gizmos and doo-dads and thingamabubs.
And the other is just two mic pres in a box.
Oh yea ... and one says "302" and the other says "528E" on the front.
The 202 and the 528 came before the 302 and the 528E, and there are significant differences between the earlier models and the latter.
But then again, there are also differences between one 302 and and another 302 ... depending on when it was made. The earlier ones used a mic pre chip that has since been discontinued. The latter ones use the INA / Burr Brown chips, which are often regarded as a noticeable improvement by many.
Honestly, I don't care if it has a transformer, a flux capacitor and an inverted lobotomizer--I just want to figure which standalone approximates my channel strip.
Thanks again.![]()
If the 202 has no tranny and the 302 does, wouldn't that mean the 202 is closer to the 528e--which has no transformer?
Or am I overestimating the effect of the transformer?
And I have a lightning source. I put it in place of the de-esser. It looks the same, but will fry the crap out of a vocalist if they hit the wrong frequency.![]()
... And I'm still looking to find any literature at all that would suggest that the 302 is tranformer-balanced.
Where are you getting this from?
... You can check out the specs at the Symetrix site. From just a quick look, I got the impression that they were close, but, surprisingly, not the same. Among other things, The 302 apparently uses an input transformer while the 528e is transformerless.
http://www.symetrixaudio.com/repository/528E_ds_EN.pdf
http://www.symetrixaudio.com/repository/302_ds_EN.pdf
(Still looking for the part about the transformer) ... still confused ... still looking ... giving up ...
That's really odd that they wouldn't show the tranformer in the block diagram, and that it wouldn't be advertised anywhere within their literature, with the exception of what amounts to be a footnote on page two on the technical specs.
I would almost need to see an email from someone in engineering / design before I trust it.
