R
RoyK
Hi all,
i've read the numerous posts and i'm afraid i've yet to find the post to cure my problems or may have failed to understand the cures you have offered.
My current setup is based around aP4 2.4, 768MB Ram, 60GB, and an Echo Gina24 soundcard. I use SX 1.06, with the main VST instruments being The grand, Groove agent, B4, and my keyboard is connected via USB 2.0.
I use the ASIO Echo WDM driver with 512 buffer size and have ASIO 2.0 direct monitoring ticked.
The two main problems i'm encountering are when i play a pattern of drums, and play the piano (in real time i do not experience any latency problems), but on playback whilst the drums are synched with the desired tempo, the piano is few miliseconds delayed (even without the drums, on playback the drums are delayed). The second problem might be related is when i record a wave using a mic or the guitar there is a delay again (on playback)and the midi and wav are not synched together. Last thing, when i record the piano vst, sometimes during the recording the tone cuts out. Is this to do with the buffer size?
Please help, and i thank you in advance
Roy
Roy
