Tadpui
I'm starting to think that there is some sort of Twilight Zone electrical situation in my house. The latest piece of gear to be affected is my Avantone CV-12. It's been quite a soldier in my home studio for the last few years...dead quiet, great sounding mic for its price range. Tonight I sat down to do a scratch track, turned on my usual vocal and monitoring chain, and there was a horrible 60 cycle hum coming through the headphones. Maybe 60 cycle hum is incorrect here...it sounds like when you unplug the cable from your guitar while the amp is still on. That distinct hum, not a buzz. This hasn't been a problem before, and I just noticed it tonight. Last time I used this mic was maybe a month ago.
I tried different cables, preamps, etc. where I could. Other mics are dead quiet at idle. The only cable I couldn't swap out was the 9-pin cable that goes from the power supply to the mic itself. That's not something that most people have a spare at hand. I even tried swapping the tube for an old ECC83 I had laying around (stock tube is a EHX 12AY7). Still hummed. FYI, the ECC83 sounded like shit in this mic
What in the world would cause a sudden ground loop in a mic whose routing and cables haven't changed or moved in a month? I leave everything plugged in and turned on all the time, including the mic's power supply (KCP&L hates me). Seriously this mic probably hasn't been unplugged or turned off in almost a year. But it doesn't get hot or anything, so I can't imagine that the heat from the tube would have loosened or damaged anything. A visual inspection didn't show any obvious damage, and the mic still produces a strong signal. It's just a strong signal with a strong hum to it.
Just a couple of weeks ago, my new (to me) Distressor went on the fritz after only a week of use. The next day my home theater receiver lost its L and R channels (OK, it was a 10 year old Sony entry-level receiver, but still...). And that same day my network switch gave out. I'm starting to suspect that this issue started during the same time frame, while the mic was idle but not in use. I'm no conspiracy theorist, quite the opposite. I'm really a skeptic. But damn, the gremlins seem to be working overtime around here lately.
