B
BilltheCat
How do you handle EQing when you're wanting to accentuate a particular range? For instance--say you want to throw the bass line out front, and really push the 800hz range. Would you be more inclined to go +4db, or would you simply *reduce* the other ranges, such that the 800hz range was at 0db, and everything else was -4db? Would it change your opinion if I said +-8db? Everthing I've read seems to indicate that Subtractive is the preferred method. Is this just one of the exceptions?
It seems like I'm adding a large amount of noise to do it at +4db, but for the life of me, don't see a smart way of reducing everything else. Perhaps I'm overlooking something.
I'm using EMU0404 and Cubasis VST 4 for what it's worth.
Cheers,
Cheers,
