M
mindsound
Of course, to each is own....I think our ears are always adapting. I'm also still tempted to find the problematic freq. in solo. It sounds more fast and easy.
But I think it's more dangerous to trick our ears when working that way. In example, an electric guitar track on it's own often seems to have too much 300 hz (approx.), so it's tempting to cut there. But working in the full mix, maybe the whole thing need that 300hz contribution of the guitar!
Also, sometimes you hear a certain freq. peaking in the mix. You are sure that is, say the bass. In solo, you'll find that freq. on the bass track and cut it out. But what was happening sometimes, is that I finally found the next day that it wasn't the bass track, it was the piano, or the acc. guitar....Tough, when I was eq'ing the bass track, I was "convinced" that the problem was there. To sum up my point about eq'ing (and even identifying problematic freq.) in solo is that a lot of times you may end up chasing your own tail. What seems to be the good decision yesterday appears to be the wrong move the next day. I strongly believe that mixing have a lot to do with our psyche at work....so at every corner, our brain (and our mind) are there to trick our ears. I'm not about all that kind of anti-rational thing, though.
But in the end, what's count most is the result. And if someone is happy with his results whatever the way he took, that's fine.
But I humbly think that it worth at least to try the way I suggest. Who knows what can happen when trying other stuff.
Anyway, the conversation is really cool. There's always something to gain...interesting this idea of running the freq. and boost/cut at the same time with 2 hands!
and Rami, I do the same thing when 2 freq. are close. That's why I love so much the oxford eq with its 4 different kind of bandwith settings.
