M
matthewmilner
Howdy! I wasn't sure where to post this question but I got such good solid advice here before I figured I would give this a shot. Apologies in advance for the long post.
Anyway I picked up a Studiomaster "Gold" 16-8-16 console for monitoring tape returns from my multitrack and making headphone mixes. The console has 16 mono inputs, 8 busses and 16 tape return channels. The price was right ($100) and the board looked like it would do what I needed.
So I set up to do some recording using the board in a 'split' monitor mode. When I started listening to what I had recorded I thought I was going nuts - levels were incredibly low and everything sounded thin and reedy. I thought that maybe the tape return mix section was to blame so I patched the tape returns into the mono channels. Sounded the same through them monitoring the stereo buss...but when I soloed a channel, however, it sounded great. This thankfully means that I haven't gone crazy or lost my hearing...but it also means that something is wrong.
Anything going through the stereo buss sounded out of phase through headphones (Sennheiser HD280 plugged into the Studiomaster headphone jack) and monitors (Event 20/20s with Crown DC150 power from the console's monitor outputs). So I started experimenting by patching the outputs of aux sends one and two into my power amp. When I stated feeding signal to the aux busses the mix sounded great - in phase with plenty of low end. The tracks also sounded great through a little 8 channel Tascam mixer.
This leads me to believe that the Studiomaster board is wired pin 3 hot. Does that sound right? It doesn't seem to make a difference on the mic inputs since the things I tracked did actually sound fine on tape...Do I just need to worry about the main outputs and the monitor outputs?
I'm using balanced TRS cables to go from the monitor outputs on the Studiomaster to the power amp. I'm thinking about making up a cable that's reverse polarity - Instead of wiring tip to tip, sleeve to sleeve - wiring it tip to sleeve. I'm hoping that would take the hot signal and get it to where it's supposed to go at the destination - Does it sound like I'm on the right path?
Any advice would be great - I apologize for the long post and numerous questions...just wanted to see what ya'll think before I start making up new cabling.
Thanks!
Matt
Thanks!
Matt
