Studio Monitors + Lexicon Alpha = HELP!
  • Thread starter Thread starter Guitar1Jesse
G
Guitar1Jesse
I am running KRK Rokit 5 studio monitors through a Lexicon Alpha (RCA connections, USB to PC). I use Cubase Studio 4. Before purchasing these monitors I tested them with my setup and they worked great. I now own them and just connected everything and they don't work through Cubase; playback is nothing but noise. On the Transport Panel the far left meter is going nuts and sometimes peaking, which indicates "ASIO Time Overload"...idk what that means. Prior to opening Cubase, I can play music through iTunes and the playback is normal. As soon as Cubase boots up the playback changes to noise, in both Cubase and iTunes.
I double checked the Device Setup and VST Connections and all are correct; set to Alpha ASIO.
I double checked the Windows settings and sound playback is set to Lexicon Alpha.
So it seems like Cubase is having an issue with my setup, but I can't figure it out. Any and all help is appreciated, thanks.
what is you asio set on in devices>device setup >asio ? whats the size of the buffer ?
First thing to try is reinstallng the drivers for the lexicon.
