Strange...Delta 44 install
  • Thread starter Thread starter jmorrisonbc
J
jmorrisonbc
Why doesn't my Delta 44 work throughmy computer's speakers? Is it becasue the speakers are plugged into the computer's on-board soundcard, and Delta is bypassing that altogether? Not a huge deal, as I have two near field monitors on the way, and I'll run them out of the break-out box....still, would like to know why.
Also, in Control Panel, I have three choices as to which setting I want for audio and recording:
M Audio Delta 44 Multichannel
" " " " 1/2
" " " " 3/4
Which one do I choose?
Finally, the two near filed monitors I have coming have RCA inputs. Is there such a thing as a 1/4 plug (for the Delta) with two RCA jacks at the other end?
You guys are great....keep the advice coming.
Johnny
P4-Northwood 2.0GHz
512 Mb SDRAM
80Gb 7200rpm HD
Delta 44
Acoustic Folk Music
Yes! Connect the speakers to the Delta.
Multichannel-drivers are normaly for games and DVD-players that got an option for surround or multi-speaker out (I think). I don't know about the Delta, but with my Inca88 I record with 1/2 , 3/4 and so on...
Yes! It's time to go capleshopping (wich I always enjoy). Have fun! :D
Hope this helps...
Also-if I am correct, it sounds like you are wanting a RCA cables that have a 'Y' end, but what you really should be looking at is getting 2 separate cables with individual adapters...you will want 2 separate lines from your Delta to the speakers. (These come from the OUT 1,2 of the Delta.
You will like the 44, I have one myself.
Microchip, ?
Microchip, do you mean that the left and right monitors should have there own outputs from the break-out box? I guess that makes sense of course, but how do you make sure you don't get a false sense of stereo?
In other words, if you route one track to Output #1, and another to Output #2, they could both be panned right or left...what procedure do you use?
John
John,
Hi again.
If I am correct, the outs on the Delta are each mono, so I don't think you would get any kind of stereo effect. I think you have to have a Left/Right approach to the outs on the Delta. Look at out 1 as left and 2 as right.
Then, when you do pan, even if just one track, you should be able to hear that in the playback.
I can't go into much more now (at work), but write back and will be more than happy to help some more.
Micro.
