K
KKristophDavion
Hi Everyone,
I've actually just stopped lurking to create a post on this issue.
Currently, I have a setup at home which consists of 2 Mikrotek-Gefell M70 microphones I got as a gift in a left-right stereo recording setup, going into a Harbinger L802 board with PP, out through main mix using 1/4" to RCA adapters going and compressing into a mono input through a 1/8" jack in my PC. Granted, yes. This is a bit of a janky set up but the mixer is much more useful to me than the Art Dual USB preamp would have been as I can take the mixer around to gigs elsewhere.
Recently, however, I've been getting a strange beeping and buzzing noise in the background of my raw recordings. It's something I can remove through the noise removal tool in Audacity, but it's something that I would like to eliminate completely if possible. I've included links below to a broad picture of the setup I am using and a 5 second damp raw recording of what is coming through my mics as of now.
My current suspicions stem from bad cabling, either due to the multiple adapters I am running through or the fact that the M70s use an outdated 7-pin XLR connection, which is going through one of Geffel's 7 to 3 pin cables. All else fails, I can check different 7 pin cables and a different mixer, as I still have waranty for my mixer.
I just wanted to see if I could get a second opinion before I did anything as rash as replacing perfectly working hardware
Thanks,
-K. Davion
Imgur: The most awesome images on the Internet
https://youtu.be/6IgliKkSy90
Thanks,
-K. Davion
