Knightfly - thanks for the comments and info, but I'm confused on a couple of matters:
1.) You say to make sure the 'fridge is on the opposite phase. But electricty is distributed as either 3 phase or single phase. Unless you're a hospital, factory, or warehouse, you're not going to get 3 phase electricty. So on a single phase distribution, what do you mean by keeping it on the other phase?
2.) You also say to use flouresents for the lighting, but my experience is that type of lighting is extremely prone to noise induction due to the ballasts. I was planning on using low wattage incandescent?
Rick - Yeah, I've been busy getting these plans into shape, and contacting contractors for prices.
I had always intended to incorporate a diffuser on the rear wall, and it will be flanked by slot resonators as well. My intention at this point is to use birch hard wood for both. I'll set the diffusers onto a 1/2 birch plywood veneer and tilt it up as one "unit".
I must confess though, I got the idea from here:
The sliding glass doors and not necessarly studio spec. but they are double pane, exterior grade. With 2 of them, it should provide pretty good iso.
As far as setting the tracks, look at this pic:
See how the tracks are set flush with the floor.
the ones I intend to use don't pull together at the center though. One door is stationary, and the other one slides.
More importantly, at least to me, is how to seal the area between the 2 rooms, just past the doors with out creating a coupling? You can see what I mean on the far right hand side of that picture.
I'm going to build a pony wall with counters, and the outlets shown in the picture will be mounted below the counter, most likely as 4 double gang boxes.
I'm also going to incorporate channels into the slab for audio cables.
For monitors, I would love to be able to splurge on a set of ADAM's, but economics dictate that I use my Event 20/20 BAS monitors for now. John said he slipped a pair in at sjoko's studio, and that they sounded great. So, I'm going with those for now for the mains. I have a pair of Tannoy Reveal's for the near fields.
Special thanks to John Sayers for providing pictures to help illustrate my ideas!
