H
Hydroaxe
I have a Sound Blaster Live card that has been working quite well for what it's worth. For some time I've been recording digital audio onto my hard drive with a 1/8 stereo mini cable (13 feet long) connected from my digital piano to the line input on the card. Since I moved my digital piano 24 feet away, I thought I'd get nice quality, 30-foot 1/4 inch cables for cleaner sound and them convert them to the 1/8 inch stereo jack with a y-adapter.
The problem with the y-adapter is that the sound card is not detecting both channels. It only detects one channel when plugged all the way in. However, if I fiddle around and plug the adapter half way in, I can get it working in stereo, but I might be getting some extra hum because of that. I've tried two y-adapters and they both have the same problem. It must be the jack on the sound card. You might ask: Do you know for sure that the stereo mini you used to use still works fine in the sound blaster jack? Yes.
My questions are:
My questions are:
- Should I buy a sound card that has 1/4 inch inputs for a left and right channel?
- Will a better sound card significantly eliminate any hum?
- Should I really be using 1/4 inch cables?
- Any idea why the damn sound card jack doesn't work properly with any y-adapter?
