sam123
Hi,
I have read the Sticky post on 'Introduction to Multitrack Computer Interface Recording'. But I'm yet confused with the digital I/O section.
It says "If you have only the stereo mix output (2 Out) then you must perfect your mix prior to or while performing, as you will not be able to mix it again once its tracked in the DAW".
Does that mean I can't record 2 tracks separately (voice and guitar) with this stereo output? Then why it is called stereo and not mono?
Also Yamaha MG102 says it has stereo outputs, what's this mean? Does the DAW see two tracks if this mixer is connected to a PC (mixer out to PC line-in)?
Tascam US-144MKII says it's a 'Bus-powered USB 2.0 audio interface', but doesn't mention anything like x-in/y-out. Does it offer multitrack recording? How do I exactly make sure if some interface/usb mixer offer multitrack recording by reading the specs?
