N
NotADrummer
Hello all, I am currently attempting to record all guitars for the project I'm doing on a Tascam 414 Portastudio. I plan on having someone else handle the vocals after all instruments are recorded, but I'm not currently settled on the way to do drums. The way I have the drums now is that I have the drum MIDI for each song loaded onto Reaper, then I have the MIDI set with drum samples from a VST and humanized timing/drum velocity to make the drums sound more real and human-like. Once that's done I connect an aux cord from my PC to the Portastudio and let the drum track in Reaper play to get the drum audio onto Portastudio tape. Then I do the standard overdubbing the guitars over the drums for each track. The problem I have doing it this way is that the drums are in mono. Now this isn't a dealbreaker for me with the current stuff I'm working on, but in the future I would like to find a way to get stereo drums using close to the same setup that I have now.
I thought about getting an 8-track recorder, and recording snare+kick on one track, panned center, and then having the toms and cymbals on two different tracks panned slightly left and right, but I'm not sure if I can get these three drum tracks recorded simultaneously using the same method from my PC to whatever 8-track I happen to get. I've looked at a couple audio interfaces like the Behringer U-Phoria with its 4 inputs and 4 outputs, but I don't see a way to output each drum track from the PC to the audio interface.
Can I get stereo drums using this method or something or is this all just totally wrong?
