steinberg midex8 midi interface
  • Thread starter Thread starter dsharp101
D
dsharp101
hey a little help here
im have problems with my midex8
it stops responding in acid and in nuendo
and when I remove the usb plug it restarts the computer (I know thats not normal)
I have a amd 64 3300 with 1gig of ram running windows xp pro with sp2
I have the interface pluged in via ac adapter as well as the usb connection
this use to be the most stable thing in my studio (set it and Forget it)
then there are times when it will work for about an hour then crap out
is it on its way out for good ???
is it a usb thing??? i have my printer (epson r200) and an external 300 gig drive and a web cam useing usb ports as well with no problems .
im at me wits end
if it a usb thing then please someone recomend something else
btw i use an alesis qs8 as my midi keyboard
thanks
odd. That is quite a bit plugged in to the USB. Sounds like a power problem, try a different USB cable or different USB port. Also see if it does it if its the only thing plugged in
