mark4man
MoonMix Studios
I have the same really bad static noise when I record tracks in Cakewalk Pro Audio 9 as I had when I posted last month. It happens both when I use my MIDI Module & when I record with a mike. I am using an M-Audio Omni I/O with a Delta-66 card; & have all my settings in Cakewalk "Direct Show Audio" set per M-Audio's recommendations (in their Cakewalk "how to guide"), except for "Default Settings for New Projects", which is set to a bit depth of 16. I also use an EbTech Line Level Shifter (which is an impedance matching transformer that converts -10db to +4db) in line between my MIDI Module (Roland JV-1010) & the Mic/Line inputs on the Omni I/O (this eliminated all the preamp buzz I had previously.) I have bypassed this device & still get the static. I have my "Variable Signal Levels" set to +4db in the Delta Control Panel. The static noise occurs along with recorded signal only, almost like a type of distortion. You hear it as the waveform plays, but it is not present during quiet passages. Any ideas? Thanks.
mark4man
Dell 700
Win98SE
512 RAM
mark4man
Dell 700
Win98SE
512 RAM
