B
Biff0r
Please excuse me if these seem stupid and easy questions. For xmas my son's present as he plays guitar and drums and wants to be the next 'Tom petty'
Anyway I bought a Roland U-8 USB from ebay at a resonable price (looked into other auctions etc and got it 2nd hand for under £100).
I have my own PC/Internet shop so I am fairly technical. But music I am not!!!! USB is Plug and Play (to a certain degree). First problem I had was that the drivers didnt work!! Installed device drivers first as per manual and most USB devices. ie plugged in and asked for drivers, I told the pc to look in the D:/drivers area as per manual. At end it came up with problem completing installation (class handler). So looked on net and found that there are updated drivers for Windows XP. (I am on WinXp sp2). These seem to work and the device is installed in My Devices (sound and game controllers). Next I insert the included CD with software Cubasis etc. First window pops up saying that the device is not installed correctly. So spent many hours removing (using their uninstall tool) as well as installing on my laptop, my pc. Same error message, i contacted the ebay seller and he told me to ignore the message, carry on installing and adjust setting in the application.
Did this and I could get guitar recording and playing in wavelab lite. But cubasis didnt do anything (tried play/recording setting) (did notice that disable audion was checked in Audio properties, couldnt turn it on), read that MODEM USB drivers can interferr with the devices, so removed all other sound stuff. Still no joy, been reading these forums most of the day and seen many topics about pre amps, etc which confusese me a little. I was under the impression i could just plug the U-8 in, install software, put the guitar directly into the U-8 and he could then start playing 'stairway to heaven'
. But now I am not sure if this si correct as the manual says for computer use you need a Guitar, external amp, headphones, mic, cables to connect them (not included)
Could some explain the set up that is easiest for me?
PS VSC 3.o wont install error on install saying about not being windowsNT compatible. <-- do I need this?
Possible that the device is faulty? as this seems to be the most hardest thing ever to install on winXp
Look forward to some interesting replies and I would like to thank you in advance for taking time to read my problems.
Regards
Biff
Please excuse the long post try and get as much info as possible.
Regards
Biff
