G
gtrboy
i have a brand new SSL preamp that costs $1800 brand new for sale. i got it for my studio and never took it out of the box. this is a high end preamp that will put your home studio up in the professional range. heres a description from the web:
SSL front end for your DAW featuring four preamps and sound-shaping circuitry from the SSL Duality console.
The XLogic Alpha VHD is a four-channel analog microphone preamp with attitude. Whether you need to track pristine vocals, crunched drums or electric guitars on the edge of sonic destruction, the Solid State Logic VHD Pre delivers a powerful and versatile sound shaping tool kit - the perfect analog companion to your digital recording system.
Based on the VHD (Variable Harmonic Drive) circuit from SSL's acclaimed Duality console, the VHD Pre adds four SSL mic preamps to any line level DAW audio interface, transforming it into a professional quality, multi-channel analog recording system.
The four ultra-clean, high-grade mic preamps are combined with independent Variable Harmonic Drive circuits that use 100% analog signal paths to generate rich harmonic distortion - adding SSL analog attitude to your digital recordings.
Variable Harmonic Drive It may look like just another knob, but the VHD (Variable Harmonic Drive) preamp is far from a traditional linear gain control - it's more like a time machine of overdrive characteristics.
When VHD is used in conjunction with the input gain control, a huge variety of preamp sounds can be created, from gentle warming to serious distortion. At relatively low input gain settings the VHD Pre preamps deliver transparent signals with all of the sonic fidelity you'd expect from SSL. As the input gain setting is increased, more of the signal is passed to the Variable Harmonic Drive circuit, increasing the intensity of the effect from subtle to extreme. By adjusting the VHD control the distortion characteristics can be shifted from 50s valve-style overdrive (if the VHD selection control is turned fully anti-clockwise for 2nd harmonic distortion) to 70s transistor-style grit (if the VHD selection control is turned fully clockwise for 3rd harmonic distortion) or a blend of the two.
Solid State Logic Alpha VHD 4-Channel Microphone Preamp Specifications:
* Connections
* Power Supply: IEC320 3-pin connector, 100 240 Vac, 50 60 Hz
* Analog I/O:
* Microphone Balanced, 3-pin XLR-F, Zin = 1k Ohms (10k Ohms for Hi Z)
* Instrument Un-balanced, 1/4" Mono Jack, Zin = 1M Ohms
* Output Balanced, 3-pin XLR-M, Zo = 40 Ohms
* Power 5-pin 180ø DIN connector, +5Vdc, ñ15Vdc
Physical
* Depth: 9" casing only (230mm)
* Height: 1.75" (1 RU) (44.5mm)
* Width: 17.25" casing only (438mm)
* 482mm / 19" inc rack ears
* Weight 6 pounds (2.6kg)
* Power < 20 Watts
Solid State Logic Alpha VHD 4-Channel Microphone Preamp Features:
* Ultra-clean, high-grade mic preamps with line and instrument level switching
* Four independent Variable Harmonic Drive (VHD) circuits
* VHD - a time machine of overdrive characteristics
* 100% analog signal path
* Ultra-clean SSL preamp with 75dB of gain
* 48V phantom power
* 20dB Pad switches that illuminate to indicate overload
* Hi Z switches to accommodate mic, line and instrument level signals
* Four independent Variable Harmonic Drive systems
* Front panel 1/4" jack instrument/line level inputs with passive DI type impedance detection and level matching
* Individual input, output and VHD controls for each section
* Rear panel XLR mic/line inputs and XLR outputs
Add four channels of SSL's hit-making signature sound to your DAW.
* Connections
* Analog I/O:
Physical
* Power < 20 Watts
* 48V phantom power
