gerard
Member
Hi all, planning on putting 8 mic pre's in a rack cage. 2 of the pre's use 2 tubes each and I'm not sure of the plate voltsge (didn't get the tube specs yet) but the high voltage tranny close to the the other solid state pre's shouldn't cause any noise problems if I'm carefull with the mechanical and wiring layout, right?
Not sure of the tube pre's origin but it uses 1 6072 and 1 6414 each. The other pre's are 2 API 990C based, 2 API(?) 2520 based and 2 Shpere pre's. Got all the PCB/turret boards, some amps, tranny's (Jensen) and "fiddily bits". I just hope there isn't any "interaction" between the tube and SS pre's with the HV tranny in there. Thanks in advance!
Jerry
Jerry
