Y
YeshuasFan
Guest
Has anybody tried the SR-16 drum machine? Has anybody A/B tested it in comparison to Zoom and/or Boss drum machines?
i had the ion drum kit which featured a rebranded sr-16 for a "brain." i'd def agree with madaudio about the sounds being dated. i also had a boss dr-550 mk 2 (?) back in the late 90's/early naughts. i found it to be less dated for whatever that's worth, but if it's an option to a get a cheap dxi, vsti, or other plug in drum machine, you might be better served.YeshuasFan said:Has anybody tried the SR-16 drum machine? Has anybody A/B tested it in comparison to Zoom and/or Boss drum machines?
soundchaser59 said:The drums on the Boss DR880 blow the SR16 outa town....
However, the SR16 is very affordable, and is best used as a sound module because of it's small size. It wont hold up to a lot of button tapping, it's better to play it by using a controller keyboard. You'll get more believable tracks that way, since the buttons only give you 8 levels of velocity sensitivity, but the keyboard gives you 128, and you'll need that to get anything believable out of the SR.
