SR-16 MIDI Question
  • Thread starter Thread starter harlon
H
harlon
Hi. I'm using my SR-16 to trigger EZDrummer and Addictive Drums. It works great for this purpose, however both programs are mapped differently. Is there a way I can save 2 different maps in the SR-16? In other words, can I set up the pads to trigger Addictive Drums on drum set 1, and set up the pads to trigger EZ on drum set 2? So far any change I make on one, also saves the changes on the other.
Thanks!
Harlon
Thanks!
Harlon
I don't know if this will work for you:
On a Mac you can use the freebie app MidiPipe. You could create a key maps where an incoming note can be remapped to any outgoing note. And you can save as many different keymaps as you want.
I don't know of any Windows freebie that does that but you might check Hitsquad.
