Spring reverb ???
Some strange reply's to this post...
SPRING reverb is different from PLATE reverb. Different construction, different sound. The OP said he wanted a SPRING reverb- why are folks suggesting a PLATE??:confused:
A plate reverb is NOT easy to build. There is a post somewhere on homrecording.com about building one. NOT a week-end project.
Plate 'verbs are not portable, either- the plate is 4' X 8', and made of steel. Then, you need a steel frame to hold the thing. You are not gonna carry that around in your Kia!! ("You can go with THIS, or you can go with THAT...")
LOTS of guitar amps have spring reverbs in them- certainly many Peaveys, as well as many other brands. Thing is, what most folks think of as the "reverb unit" is actually just the "tank-" you need lots more than that to make it work. Yanking that stuff out of a PCB-wired guitar amp is way more trouble than it's worth, and taking it out of a P2P, hand-wired tube amp is just wrong.
OP, you might get by using the reverb in a guitar amp, if the amp has an effects loop. It WILL "work," but no promises as to how it SOUNDS. Try it and let us know.
It's been my observation that the spring reverb unit is usually the first thing to go on most old-school PA's that have them- be sure the reverb works before you, ahem, SPRING for one of those for the reverb. Newer PA's with 'verb will almost certainly be DSP, which is not what you want.
A quick and dirty test for a reverb tank that is fading fast is to wack the top of the cabinet with your fist or hand, when the unit is turned on and ready to play. A thunder-sounding "reverb crash" (unmistakable, so I won't describe it further) is a bad sign. Very cool sound, though...:)
Guitar-amp spring reverb units (add-ons) are available, but not cheap.
Pioneer or other home-audio makers used to make reverbs for home stereo- they sound HORRIBLE. Avoid them unless you want a unique, and horrible, sound. Some were NOT spring reverbs- those sound even worse.
Oh, and you will NOT need a long mic cable to record the echo in the Grand Canyon- the sound comes BACK to you (that's what they call an "ECHO!") so the mic cable need be only long enough to go from the stand to the recording machine.
Well ... he said he'd heard of spring reverb, but he didn't necessarily say that's what he wanted. He just asked if anyone sold "reverbs" without all the extra fluff effects. And he said he wanted "real" reverb, which has been discussed.
To the OP, there are a bunch of online threads about building your own spring reverb. I've considered doing this myself, but I haven't attempted it yet. There are even plans to build one out of a $1 toy echo mic. I'll definitely be doing this when I finish a few other projects in the works. It sounds pretty damned good too! :)
Here's a link for that:
the squarewave parade
And here's a link for a larger spring reverb. I haven't heard any sound samples for this one though:
Build your own spring reverb - Do-It-Yourself Projects - Home Recording Studio Help
And yet another even more complex one built from (among other things) a Slinky:
The Electronic Peasant's Slinky Spring Reverb Page
You can still get the Accutronics unit found in virtually all guitar amps for around $25 brand new. Just sayin'.
best reverb I ever heard was in the bathroom of the last place I worked.
Spring reverb was the cheapest way to create a reasonable analog reverb... and always sucked to a certain degree (unless you were looking for that particular guitar sound... I wound never consider it a great classic analog reverb... just a spring reverb that should have never have left the guitar amplifier case
