I don't know if it's been mentioned yet (I really couldn't bring myself to read the whole thread), but there is a problem with using the haas effect to create pseudo-stereo.....
I think it's a bad technique for emulating doubled guitars and would ask, why not just do the damn double?
I get what you are saying...but...
1.) This approach has nothing to do with trying to create pseudo stereo. God knows, I've argued that same point with newbs a hundred times, that two mono tracks don't make stereo.
2.) And again...it's not an attempt to *emulate* double-tracked guitars out of laziness or any other reason. I generally record a bunch of the same tracks all the time, and then listen/pick the ones I like...so it's not that much of an effort to double-track.
The thing I was/am trying to discuss is how one can use the split/copied delayed track to create all kinds of imaging flavors by panning and by also setting the delay so that both work with the rhythm/BPM of the song.
Yes, if you pan them hard/wide L/R the primary track always pulls a little, and the delayed follows it...but that IS the point.
If you pan them very slightly, you get other kinds of flavors....and while I agree that you can do all that with a double-tracked pair...I also note that sometimes it's specifically the *identical quality* of a split/copied track that is the point, as it's a perfect mirror, which adds to effect. Yes, other times you want the small imperfections of playing twice.
I'm not suggesting or condoning the use of this to replace double-tracking...NOT AT ALL...yet  it's something you can use in combination with other tracks that are double-tracked or recorded in stereo. It opens up all kinds of layering/contrast possibilities.
Mind you...if you are doing a basic/typical 3-chord rock tune - drums, bass, guitars...then there may not be any realistic way that you will use this, but with more involved productions and instrumentation, it opens up the possibilities of things one can do to take the mix a little beyond the obvious. If you look toward electronic/trance/dance/head music, this is nothing new, and I was just looking to discuss production techniques where it can be applied to other styles too.
Here's a short example I've mentioned a couple of times in the past:
Record a nice Rock organ track with some rich vibrato.
Now take that and split/copy it in the DAW.
If you look at the organ track....the vibrato creates an up/down wave that is easy to see.
Take your copied track and slide (delay) it so that the UP portions of it's vibrato wave fall perfectly in the DOWN portion of the original track.
Pan them hard L-R...don't add any other kind of delay FX or reverb (though sometimes a pinch of reverb to both adds an airy feeling).
Now listen to the cool L-R "pulse" you get, with the organ filling out the stereo image wonderfully even at low levels, but without overpowering the mix.
Sure...you could record the organ twice...but you will NEVER be able to get that perfect L-R pulse since there is no way for you to play the organ track so the the vibrato fits perfectly in that UP/DOWN combination.
Of course...playing twice is yet another flavor that could sound good on its own merit...just like the guitars thing and everything else...this is just another possibility.
I will put up a few audio samples at some point of various double-tracked and split/delayed combinations so people can hear them and compare. I think there are many ways one can work tracks, though sure, if all you want is a specific sound/vibe ALL the time, then you would obviously record every song with the same SOP...which is also OK, and there have been many bands/artists that simply stuck to a single production style and it worked for them.
Peace...love...& understanding....
(Hmmm, that could be some nice lyrics...
