speedy fingers.
  • Thread starter Thread starter marshall.amps
M
marshall.amps
Any body know any good "speed exersices" like hammer on pull offs that crap for getting faster.
There's no such thing. You are either born with it - or you suck.
You don't sound like you were born with it......
Try this...take a hammer in your right hand, smack the fingers on your left hand, if nothing else..it'll make you scream faster! :eek:
Alrighty:
1. Get a metronome.
2. Learn some scales.
3. Play them along with the metronome at the quickest speed you can perform the scale cleanly.
4. Speed the metronome up by 2 clicks (about 8 bpm) and play the scale to that. Do the best you can.
5. After sucking at this speed, bring it down a notch (about 4 bpm). You'll note that if you just try to go up 4 bpm from your original speed, it won't be as easy as going past it and then back down.
6. Do this with other scales, scalar patterns, licks, scales w/ hammer-ons and pull-offs, go nuts.
I tried useing a hammer but it kinda hurt me so im not sure it will work but no pain no gain so ill keep working with the hammer.im gona try the metronome i dont realy know how to use em but ill fiugre it out.
Use the hammer on your head and you will think faster...try it for a day!!! ;)
aaaaaaa yes thats a good idea! wait wont that hurt though?
Did you use a ball pein? A sharp claw hammer usually does more damage if used properly. Then pound in about 3 lbs. of rock salt!
actually i drilled some holes and tried putting books in my head for knowlegde
there in there but i have to tape em in there and i did put some salt in there cause im a cracker and well crackers need salt for some flavor u no
azraelswings said:
Alrighty:
1. Get a metronome.
My metronome (and tunner) is a fender its blue see through and black on the back it ticks and then on the 4ht beebs. I would set it at a speed were i could play the riff be4 the beep i did get faster today i played for about 3 or 4 hours strait.
