T
The_Raven
Howyadoin,
Here's the specs for the DAW I'm building... If anyone knows of a reason why these components should not be wed, speak now before I hold a piece...of @#$@!
Mobo: MSI K7N 420 PRO - nVidia nForce chipset, UDMA 100, onboard gForce MX graphics and 10/100 Ethernet. No RAID support.
CPU: Athlon XP 1700+
RAM: 256 MB DDR
Drives:
(1) Maxtor 30GB - system drive, UDMA 66 7200 RPM
(1) Western Digital 80 GB UDMA 100 7200 RPM
Audio cards:
Delta 1010 (analog/digital)
SB Live (for MIDI)
Burner:
Plextor 24X IDE
O/S:
Win 98SE
Software:
Cakewalk Pro Audio 9
Sound Forge 4.5
I assume I'll need some MIDI interface since the Delta doesn't have it, so I specced a SBLive just to handle MIDI. Is there a better choice in the same price range (~$50)?
What is your experience with 98SE for DAW apps? I've had pretty good success on my home rig with just an SBLive, at least as far as stability is concerned. Is Win2K a better choice for stability? Plus, with 2K I can run 512 MB of DDR RAM and have it all available for cache, as opposed to 98SE which kinda wastes anything over 256, right?
Also, I'm speccing a nForce mobo because I've heard the VIA horror stories... Is this still the case with the newest VIA chipsets?
Lastly, should I be thinking about SCSI for the data drive to avoid IDE bus contention? I'd rather not spend double the money for a SCSI drive, and I'll already be splitting the system and data drives between the primary and secondary IDE controllers, with DMA enabled for both.
Any input would be appreciated... I've put together more than a few rigs in my day, but I'm a n00b at building a DAW box. TIA for any assistance!
-Rav
RAM: 256 MB DDR
Drives:
Audio cards:
SB Live (for MIDI)
Burner:
Plextor 24X IDE
O/S:
Win 98SE
Software:
Sound Forge 4.5
-Rav
