bought a pv 1500 which comes with speakon outputs and no 1/4" jack outputs, which I was used to. What are the advantages of speakon? for now i have to adapt my cables to use the binding post outputs instead.
thanks for your help.
a little different question...
but do you know how to use my active speakers with speakon cables with my Behringer Xenyx 802 non-activemixing desk...it does not have speakon connection.
Or maby you know who can help. This is for live performances.
Thanks
You can make Speakon cables pretty easy. Just buy the ends and get lamp cable at the hardware store. Should be cheap, way less than 1/2 what they sell them for. I made some plus some Speakom to 1/4" cables.
Adaptors should not be needed. Others have mentioned speakon to 1/4 adaptors for high-level amp outputs, which is fine. But speakon is not used for shielded cable.Active speakers need to use shielded cables, because since the signal is going to be amplified, any RF that it picks up as an antenna will be amplified too. So for them you could make up some cables or it might be simpler to buy those adapters like others have mentioned.
What I don't like about the adapters is that they always seem to stick out in the worst places on stage and are real easy to run into.
My JBL speakers have Speakon and 1/4" jacks, I don't see what the problem is and why more companies don't do that. I've thought about adding 1/4" jacks to a Behringer pa I have that only has Speakon. What's nice about 1/4" plugs is that you can use a right angle one and put your amp right against the wall.
