Hey Rochey !
Rochey, I appreciate you taking the time to help me
few takes on your response.
What im looking to do is be able to have all my instruments hooked up and ready for recording, the option to have more plug ins and not have to keep unplugging everytime you want to record a new instrument is my concern.
S/PDIF seems to be the way to record. if the rackmount box has a S/PDIF out, wouldnt anyone that uses an instrument that doenst have a S/PDIF out, plug into the box so that the signal sent is digital? ex. my Zoom 123
the only instrument that i have that has no S/PDIF is my Zoom drum machine. If i could plug in all my instruments ready for recording and plug in my Zoom 123 to convert it to digital i can do it all in one shot with the rackmount box?
Okay, now on to my 24 channel mixer..
Ill use my Zoom for example. if i plug my zoom into a power amp and have my monitors connected to the power amp i seem to get a better sound than going through my board.
reason? im not sure... but each channel on the board has its eq, and the sound is being affected by this...
If you have S/PDIF like for my J-Station, wouldnt it be better to connect straight to the card as opposed going through the board? doesnt that defeat the whole purpose of the S/PDIF?
Let me give you my specs and if you could possible point me in the right direction i would appreciate it.
CPU= XP 1700 new MSI Nvidia chipset mobo, 512 DDR ram..etc. etc. top of the line computer
Cubase 32/5
Gina card (old one 20 bit) <--- i need 24 bit
24 channel Peavey MS 2421, powered by QSC amp
J-Station --- S/PDIF outs/analog outs
Zoom 123 (love this little baby) "No" S/PDIF outs/ analog only
Roland RS-9 synth S/PDIF outs/analog outs
Studio rackmount, outboard Roland effects etc
Since i love the true sounds of outboard effects like my rackmount Roland this is how i was told to get the best recording. To go straight into the card and record to cubase. (record dry)
Then i can set my bus up in cubase where i can have say only tracks 1 & 2 ( the drum tracks)be the only out, then the out from the card to say channel 1 of the mixing board, from there i can loop to the rackmount effects to add some reverb to the drums and so on.
So when i get the desired sound i like, i then re-record the drums to cubase and erase the old drum tracks.
My J-station & Synth is okay to direct S/PDIF record because of the buildt in effects which are pretty decent.
So to break it down, From what im told, to get the best signal is to record S/PDIF, (if your instrument has that feature) straight to a sound card, going through a board first would defeat the S/PDIF purpose, right?
So i quess what im really trying to do here is to have all my instruments "ready" for recording along with the only non S/PDIF, my zoom so that i can convert it to digital all in one shot and have the S/PDIF outs going straight to my card
Okay, My brain hurts now...
With my above specs, if you or anyone can tell me the best way to get the best quality recording I would appreciate it.
Oh, and by the way, heres a link to my homepage of my first computer recordings last year. Gina 20bit card, which i still have, im a gutarist and i used my Digitech 2120 <-- nice unit, and plugged the bass straight in as well as a cheap casio i had before i got my RS-9
Eddie's Recordings
used the cubase drums for this, its all instrumental.
Thanks alot for any help anyone can provide
