Soundcraft Ghost Le Pres
  • Thread starter Thread starter alan6202
A
alan6202
I am about to purchase this board to run all my channels out to. Are the pres good or will i need to invest in dedicated pres? Will be recording all live instruments jazz and gospel. Right now on the front end will be apogee converters.
I've got a Ghost and they are pretty decent. Definately good enough for most situations but you may want some gold channels for important stuff. It just depends on how good you need it to be and how deep your wallet is.
They are the Daewoo of preamps. Not great, not completely horrible either. If they are well maintained they will get you there, but not in luxury.
Nathan Eldred
atlasproaudio.com
Ahhh... But they are modifiable...
Call Soundcraft and ask them about it - They can make them kick serious a$$ for a pretty reasonable amount.
If they can't get you the number, PM me and I'll find it - A studio I freelance at got mods on their preamps - They rock.
John Scrip - www.massivemastering.com
i've heard if you mod the PSU on the soundcraft inceases the headroom of the entire board and the pre's sound cleaner...its supposed to be not TOO expensive either...not sure who does it though....probably jim williams
All apt descriptions....Realize this.The Power Supply of the Ghost is a regulated one.On one rail.The 'other'rail is not.Add voltage and get creamy rich delectable sound.Sound that when driven hard starts to get that....uhh....Pro sound.Be careful what you add and where.Its not for beginners.
As to the original poster's question...The mic pres are good.Basic good.They will do no harm.The EQ is very nice.The routing is superb.The playback will sound like the recording.Good luck.
thanks I will get something like the digimax for drums and probaly the Isa 428 for vox alon with a 2 channel converter.
It sounds like a good move to me.
I have the ISA 428, it is a great set of pres, especialy for the price.
Clean, smooth, and warm is how I would describe them and lots of juice too!
Below is the response I got directly from Soundcraft.
Hi Bill,
Why would you want to upgrade these pre-amps? (OK, that was a rhetorical question..!)
Seriously - This pre-amp design was developed especially for this console, and was quite innovative in it's day. The only things I can see that would be useful would be to:
a) beef up the electrolytic DC decoupling capactitors (higher value and working voltage, if you can find a suitable replacement with the same lead pitch). This may improve the frequency response. If the console is fairly old, and has been used well, this process of 're-capping' can sometimes make a significant difference (as with all audio equipment) because the electrolyte in these devices can dry out, affecting their frequency response.
b) use a higher spec op-amp in the mic-pre stage (IC1). The TL072 used is a very popular low-noise choice for practically all mixer manufacturers, but, as with anything there will be a higher spec device which may provide a 'perceived' improvement in audio quality. You could try using NE5532 or MC33078 devices, but I don't think you'll hear a significant improvement. (In fact, you may even cause more problems, like high-frequency instability by using a different device)
So, this is all just my opinion of course, and I can't stress enough that any change to the design cannot be sanctioned by myself should anything untoward happen due to this type of tinkering!
Hope this helps.
Best regards,
Ben Libby
Customer Services Engineer
Soundcraft
T. +44(0)1707 668 169
F. +44(0)1707 663 114
My $.02 worth, I would just go with the stock preamps and not worry about it. There are people making albums with a whole lot less! Down the road you may want to add a couple of higher quality units to take over the bulk of your work.
Eventually, get yourself 2 nice channels as I have done. It will make a world of difference.
War
Warren Dent
www.frontendaudio.com
