Are you using your tie lines and how are they terminated?
No, I am not using the Tie Lines, yet, but I do have the Tie Line Elco cables. they are terminated with a combination of XLRs, 1/4" and RCA connectors. The previous owner had this seriously connected to a lot of outboard gear, evidently.
If you are not using your tie lines, you can reconfigure your tie line Elcos to the Tape Send/Return pinouts. To do this you open up an Elco, pop out the pins, and then put them back in following the Tape pinouts. For this you may need an Elco extractor/insertion tool.
Mmm...not quite sure if we're on the same page here...all my tape Send/Returns are working (via 3 seperate ELCO snakes). That part works OK. Three snakes feeding all 48 INs and OUTs on the back an Alesis HD24. Super. This part is very tidy. It's the Tie Line cable configuration that I'm baffled by - dozens of connectors, and I don't even know what's a Send or what's a Return, let alone to where, ha!
Another thing he recommended was to look on EBay for Elco snakes in the ADAT standard. Looking for the ADAT standard should mean 8 sends and 8 returns per Elco. Then, when you get the snake, you reconfigure the Elco side to match the 6000's tape pinouts.
Gosh, I wish I had someone like that near me. Sounds like he's been really helpful to you. I would have taken the Ebay route, but then I learned the previous owner had thrown in all the ELCOs anyway.
I got lucky and found Elco snakes on EBay for a Soundcraft Sapphyre that, as far as I can tell by reading the documentation, follow the same pinout diagram as the tape pinouts for a 6000. The auction also came with some great tie lines but it seems as though those pinouts are a bit different.
Ha, I think I saw that - about a month ago, I think that was.
Also, there are some
Soundcraft 6000 and 600 (little bro. to the 6000) owners over at the TapeOp message boards. You might try posting your dilema there:
http://messageboards.tapeop.com
Awe, you've been too kind. Thanks. I'll do just that. there doesn't appear to be too many 6000 users around here.
Just some ideas to maybe help get you going. Keep me informed as I'll soon be experiencing the same thing you are!
Definitely. Thanks.
