soundclick player how?
  • Thread starter Thread starter TAE
TAE
TAE
All you have is now
Seen others do it how do you get a soundclick player to embed here?
Never seen a soundclick player embedded in the site, just links to them. I hope you get it figured out though, cause I would like to see that myself.
Trump
Here's what ray told me a couple of days ago. It preoduces a link that, when clicked, pops up the streaming player for one song.
You can get the hi or lo or both links from the "new band administration" page. You go to you admin page & in the URL section it has a blue link to link/embed tool. THat's where you get it!
It's easier to find in the OLD band admin section.
Here's a link I took from my link/embed page for my latest track. clicking it should cause the streamer to pop up straight away.
http://www.soundclick.com/util/getpl...=10044771&q=hi
I haven't been able to find the page where to get the url with the "util" word in it like rayc did. If you want to see his player work, then you have to go back to the original post where he embedded it https://homerecording.com/bbs/gener...ing-clinic/moar-fuk-pleez-316274/#post3561857
However, if you go to your songlist in you band page, there is a link next to each song that says "full." Click on that and you get a url for a page that contains the streaming player for that one song, with buttons below it for hi fi, lo fi, and download.
If you want people to be able to download it and port it to other systems that might be offline, then you want to right click the download button, select properties in the menu that appears, and copy the address url that pops up and use that as your link. The link will pop up a window to open or save the file, and opening it causes it to play in your default player.
Member Login
Otherwise, you can copy the url above the buttons and using that as the link will stream your song automatically.
SoundClick artist: tonesponge - page with MP3 music downloads
If you play your song and click on the share song link on the widget, you get the same link tp pop up to copy:
http://soundclick.com/share.cfm?id=10016715
