I didn't wanna start a new thread if there was a related one so ill tack my question onto the end.
Basically I'm looking to get into home recording etc
as far as soundcards go it looks like a toss up between a Delta 44 and Delta 10x10lt...
anyway, as far as the Delta 10lt, would it work fine if i used mic pre amps infront of the channels?
e.g, If I had 8 mic pre amps, i would be able to use all 8 channels of the card?
as far as i know to use any of the channels on Delta 44 or other delta cards you need a preamp or mixer infront of every channel anyway, so is a 10x10 basically the same as all other delta cards except it doesnt have a breakout box (bar the slightly different dB and THD rates)?
thank you in advance and sorry if some of the questions are mindnumbingly obvious
