F
freakkguitarist
should i screw thre soundboard to the studs, then the drywall to that, or the other way around forthe inside wall for my drum room?
freakkguitarist said:should i screw thre soundboard to the studs, then the drywall to that, or the other way around forthe inside wall for my drum room?
As a designer, I would never intentionally introduce a product that would put someone in jeopardy
Not all foam products are manufactured for fire resistance because not all applications of foam require it. For example eggcrate foam used as packaging cushioning has no particular need or requirement to be flame rated. Some sometimes folks go to a craft store and see eggcrate foam and say 'woah, this stuff is WAY cheaper than the name brand stuff...I can buy twice as much' As a general rule if it doesn't say that it is flame retardant it isn't.RICK FITZPATRICK said:I was under the impression, as I would guess a lot of people here are too, that these products were manufactured to meet a fire retardant spec. Thanks for the reply Jack. BTW I too am interested in your help. You caught me off guard in the other thread.
fitZ
A lot of different materials call themselves 'sound board'. Certainly Homasote 440 Sound Barrier does not require this from their published directions. They recommend nailing or gluing as an interlayer between stud and gypboard.Acoustech said:No ..No ...No.. Sound Stop is a fire hazard......always sandwitch sound stop between FC-fire code 5/8GWB
Acoustech
