OOOOOOOOPPS!
Sorry Benirose. I seemed to have got my numbers mixed up. What a dunce. Its been over two years since I delt with this stuff. Ok, heres the deal as far as I can tell from Owens Corning.
R-13 is the one that is for 3 1/2" deep stud cavities.
R-19 IS actually 6 1/4" thick. It looks like this is for attics.
R-21 is 5 1/5" thick. This looks like the one for 2x6 studs.
R-38 is 9 1/2" thick.
Well, it looks like I've done it again.
Ok, again, sorry Beni. At least I've corrected it and learned another lesson myself.
Heres the site with the correct info.
http://insulation.owenscorning.com/professionals/insulation-products/all-products.aspx
Will R-19 do any sort of help to my basement or is it a waste of money? I'm looking for the cheapest alternative to getting some sort of sound absorbtion, as I have concrete walls and a low plaster ceiling, but if you say save up for 703, I'll take your word on it, since you've been very helpful and know your stuff.
Beni, I will stick my neck out again and say this. First off, I'm certainly no exper so I try to rely on what info I can find on the net. What I've found is the difference in cost between FIBERGLASS batt insulation and RIGID Fiberglass is substantial. However, you might want to consider those ULTRATOUCH COTTON batt insulation. I checked the absorption coeffiecients and for the price I don't think you can beat it.
125hz 250hz 500hz 1000hz 2000hz 4000hz NRC
R-13 3.5" (mm) A 0.95 1.30 1.19 1.08 1.02 1.00 1.15
R-19 5.5" (mm) A 0.97 1.37 1.23 1.05 1.00 1.01 1.15
Pretty damn impressive.. I'm surprised more people aren't talking about it.
I found it here
http://www.bobgolds.com/AbsorptionCoefficients.htm
and heres more on it.
http://products.construction.com/Ma...044/products/Ultratouch-Insulation-NST14666-P
http://www.soundaway.com/R19_24_UltraTouch_acoustic_insulation_p/22004.htm
For FOUR Ultra touch COTTON batts..5 1/2" thick, 24" wide and 94" long the quote is $85 for 63 square feet. Thats the physical size equivilent of TWO 4'x8' sheets of rigid fiberglass...or...enough to make EIGHT panels 5 1/2"x24"x47" . Considering you have concrete walls and plaster cieling, and the absorption coefficient I don't think you can go wrong with this product...if you can get this specific model:
I looked here but didn't find it. Maybe you can call home depot. And then, maybe again, the 3/12" thick stuff wouldn't be too bad either. Looks like homedespot might be a bit more expensive but I don't know considering availability vs shipping. You have to do the rest of the homework yourself cause only you know whats available around your area.
http://www.homedepot.com/webapp/wcs...3&productId=100656746&N=10000003+90401+527407
Anyway, I'm outta time. Sorry for the misinformation. I hope this makes up for it.
fitZ
