P
PABLOCK
I have a Creative labs Audigy 2 Platinum and here are the specs. We planned on recording at home instead of paying for the studio, this way we can have an asset when its all said and done for our company. Heres the specs for the Audigy. I paid around 250$ canadian for it about a year ago. For the kind of performance Im looking for is this adequate? Where is this one lacking? Thanks
Audio Performance
Signal-to-Noise Ratio with AES17 filter (A-Weighted)
2V Rated Output 1V Rated Output
Stereo Output 106dB 102dB
Front and Rear Channels 106dB 102dB
Center, Subwoofer, and Rear Center ~90dB ~86dB
Total Harmonic Distortion + Noise at 1kHz 0.004% 0.004%
Frequency Response <10Hz to 46kHz <10Hz to 46kHz
Technical Specifications
High Definition Audio Quality for Playback and Recording 24-bit Digital-to-Analog conversion during playback with sampling rates of 8, 11.025, 16, 22.05, 24, 32, 44.1, 48, and 96kHz in 5.1 mode and up to 192kHz in stereo mode
24-bit Analog to Digital conversion during recording in 8, 16 or 24-bit at sampling rates of 8, 11.025, 16, 22.05, 24, 32, 44.1, 48, and 96kHz
SPDIF (Sony/Philips Digital Interface) input at up to 24-bit / 96kHz quality
SPDIF output up to 24-bit at 48 or 96kHz
ASIO drivers for low latency (=2ms) multi-track playback and recording at 16-bit/48kHz)
Wave-Table Synthesis and Midi Features
Creative Hardware synthesizer (2x16 Channels) with 64-voice polyphony featuring E-MU®'s patented 8-point interpolation technology for accurate sample reproduction
Creative Software synthesizer - multi timbral wave-table (16 Channels)
SB1394/FireWire® Connectivity
IEEE® 1394 / FireWire® / i-Link® compatible interface with up to 400Mbps transfer rate
Sound Blaster Audigy® 2 Platinum On-Board Connectors Line level out (Front / Rear / Center / Subwoofer /Rear Center)
Digital Out for 5.1 support (6-channel SPDIF Output)
Line in
Microphone in
SB1394/FireWire port
Telephone Answering Device in
Analog / Digital CD Audio in
15-pin MIDI / Joystick port extension header
Internal SB1394/FireWire header to Sound Blaster Audigy® 2 Internal Drive
AD_EXT extension header to the Sound Blaster Audigy® 2 Internal Drive
Sound Blaster Audigy® 2 Platinum Internal Drive Front Panel Connectors Headphone Out (1/4" Stereo Jack with Volume control)
Line In 2 (1/4" Stereo Jack, shared with Microphone In 2)
Microphone In 2 (1/4" Jack with Gain control)
MIDI In (mini DIN)
MIDI Out (mini DIN)
Optical SPDIF In and Out
Coaxial SPDIF In and Out
Stereo Auxiliary In (2 x RCA/Coaxial Jack)
Infra-red Receiver
Audio Performance
Line in
Microphone in
MIDI In (mini DIN)
MIDI Out (mini DIN)
Infra-red Receiver
