Sound Card Poll ...... which is best for the money
  • Thread starter Thread starter YngwieMalmsteen
Y
YngwieMalmsteen
Aardvark: Aark 24
Aark TDIF
Direct Mix USB3
Direct Pro 2496
Direct Pro LX6
Antex: Studio Card 2000 Plus
Echo: Darla24
Gina24
Layla24
Mia
Mona
Frontier Design: Dakota
Dakota/Tango24
Tango24
M Audio: Audiophile 2496
Delta 44
Delta 66
This seems like a trick question. Since these cards differ by HUNDREDS of dollars, what is the point?
Is the Aark 24/96 a good bang for the buck? I'm thinking about getting one and it looks like a good deal, but does it have pres on all the channels??
Justin
Aardvark Q10 is a nice all in one (preamps) package.....
Yes, the Aardvard DirectPro 24/96 has solid preamps with phantom power on all 4 channels. It also has "zero latency" monitoring with eq, reverb, and compresson on all 4 channels. (The effects don't work at 96K sampling rate) I just put my money where my mouth is and got one last week. So far, I'm loving it - the quality of the sound is amazing. That's not to say that other cards wouldn't be fine for you too - just that this one rocks for me.
For a site with technical comparisons of a pile of soundcards, see http://www.pcavtech.com/soundcards/index.htm. This site compares jitter, distortion, dynamic range, noise, frequency response, etc. for a boatload of cards.
-lee-
In this order:
Aardvark Q10 (all-in-one + super sound qlty)
ST Audio DSP2000 (cheeaaaapppp)
Delta 1010 (not lt. Never heard it but I trust it by its popularity here on HR.com)
Dead Poet- how are the pre amps on the staudio? How solid is the construction of the box? Maybe tricky questions to answer, I'm just looking to see if the st-audio stuff is "cheap" or if it's just "cheap" if you know what I mean. :)
Depends on what your needs are. For me I went with the Q10 and am very satisfied. If you need 8 ins (with 4 preamps) its solid and quality sound now that they have worked out the driver problems of last year.
dan
Well, I'm very happy with it.
I don't know how familiar you are with ST-Audio's product line. They have a sound card (DSP24) with a capability of 10 in - 10 out + several break-out boxes. The ADC&DAC2000 is the cheapest with two pre's and unbalanced line ins/outs (8 analog, 2 digital via optical or coax S/PDIF or AES/EBU!, talk about choices!)
The pre's are ok (only had the chance to ocmpare to Behringer MX-series mixer). If you turn the gain past 2 o'clock they get noisy, but that's where most of the gain lies.
Construction is good. I read some newsgroups and there is like a 1% of customers with real (fysical) problems. Solid metal body and 3 metre cable so you can keep computer or other interference out.
This card is a bit picky about your chipset (mostly AMD problems pre VIA KT266a related) but latency is great.
I'm planning on expanding my home studio with a real mixing board and a standalone recorder, so the STAudio will be a good editing machine and effect processor while saving up for real outboard gear (.5ms latency at 96kHz so usable for realtime monitoring).
Convertors in the ADC&DAC2000 are the same as in the delta 1010, those in their 3000 box should be better (8 pre's, adat & balanced in/out, wordclock, the whole shabam at about $1000 with the DSP24 card)
Up to four cards can be fitted in one system and I read about a guy succesfully having a 3-card studio (24 simultaneous in, +20 phone mixes)...
Goes a long way for a relatively unknown budget card. Those Taiwanese engineers supplies us ;)
Herwig
