P
PRiZ
sorry for all the posts about this...
What exactly can The lynx one not sample at 96...?
I feel like I'm getting mixed messages.
It says I can record digital at 96, is this not MIC, is mic only recorded by analog...? If this card has support for up to 32-bit wouldn't 32/41khz sound better than 24/96khz...
basically what is digital I/O used for...
I'm sure this will be easy to answer.
here are some quotes.
"Sound quality sets a new benchmark for a single card solution with support for up to 32 bit/96 KHz recording. A/D and D/A conversion is 24 bit."
"Some musicians will be put off by the lack of 96kHz capability for analogue recording and playback."
"The Lynx One drivers support MME, DirectX, and ASIO, along with 8, 16, 24, and 32-bit file types (32-bit files contain 24-bit data with padded zeroes, and can reduce processor overhead compared with 24-bit ones)."
"Supported digital sample rates: 32kHz, 44.1kHz, 48kHz, 88.2kHz, and 96kHz."
"although these chips are capable of 24-bit operation, they are limited to a maximum sample rate of 50kHz; I subsequently discovered that the Lynx One was first launched in America in October 1998. Its digital I/O can, by contrast, be used at rates of up to 96kHz."
"96kHz sample rate is only available for digital I/O."
"Only its lack of full 24/96 analogue capability and an optical digital interface will dissuade musicians, along with its comparatively high price for a stereo-only card."
P.S. If this card can't record at 96, why is it so worshipped for it's great sound...? I'm stumped, I know 96 sounds better and makes a noticable difference.
This card might not be the one, but I can't find any other cards that are...is RME's DIGI96/8 pro sound better than this, but more importantly does it work with an athlon computer, It' has this spec written that says "Windows driver with Pentium¢ç optimization (quad times memory transfer)" is this for athlon too, I'm confused if I can run this soundcard...help!
and I always here about Lucid, but I havn't ever found a soundcard by them just converters.
