samth3mancgp
I have an old (isn't almost everything in this forum?
) Sony TC-377. Since I got it out of my grandpa's basement where it sat for 15+ years I have had problems with it. It will move the tape fine, the motor and all of the belts work enough to move the tape at the right speed, But the sound coming out is troublesome.. I had a thread on AudioKarma about the Sony. To make a long story short; when the recorder was at my school there were seceral days where it worked by a stroke of luck for about 2 days. We were able to record and playback magnificently! But all the time before that and since There has been the same problem with almost nonexsistant record levels and thin playback.
Right now It sits taken apart about as much as it possibly can be where all the boards are still soldered in and it is possible to test. I have already tried switching out several caps but I put most of the originals back in. I even after searching on google and reading alot about testing capacitors I still don't know what I am supposed to do. My multimeter has a setting to test micro farads but it dosen't read any differently when touching a capacitor. I want to start with just replacing caps on 1 channel of playback and 1 channel of record. I see how the circuits are symmetrical and have the cables running to the heads on opposite sides of the board. I will probably replace every cap on the rec/playback boards using parts from radio shack, but I still would like to know how to properly test them. I'll just bring the parts list from the schematic in and get the parts I need.
