Sony Apr 5000 I can't operate it
  • Thread starter Thread starter reelshows
R
reelshows
Just brought home a real nice APR 5000. Problem is, I have no owner's manual. I have been trying to play older tapes and I have been hearing both sides of pre-recorded tapes, I know there must be someway to turn off the other track(playing backwards), but I can't figure it out.
Maybe there is some kind of alignment, or maybe one head is on that should be off?
Please let me know what I'm doing wrong.
I hate to say it but there's a fairly good chance this machine simply will not do what you need. Quarter-inch stereo tapes come in two varieties:
1. Half-track stereo. This uses the entire width of the tape for two tracks, which means that it can only play in one direction. This a high-quality format used for mastering, which is what the 5000 would have been designed to do - putting the tape on in reverse will play the recording backwards.
2. Quarter-track stereo. This has the recording split into half the width of the tape. The quality is reduced but you can flip the reel over like a cassette and play two sides worth of audio. This is most likely what your tapes are recorded in.
So. If you have a machine designed to play back 1/4-track recordings, you can put a 1/2-track tape on it and play it back fine, albeit with slightly less fidelity. But, if you put a 1/4-track tape on a 1/2-track deck, you will get both sides playing at once, one of which will be backwards.
Now. I don't know much about the 5000, it being amazingly expensive and out of my league. Do you know how many heads are installed on it? It's probably either 3 or 4.
If it's three 1/2-track heads, you've got a problem. If it has 4 heads, one of these is often a 1/4-track head so that it can play back 1/4-track tapes, i.e. exactly what you're trying to do. In which case there should be a switch somewhere to flip it over. (The Otari 5050 is like this)
If it is a 3-head 1/4-track deck, which unfortunately is quite likely, your only option would be to replace the playback head with a 1/4-track one (this will make things awkward if you ever need to record on the deck!).
You could probably get some from JRF Magnetics, but they are not going to be cheap, especially if they have to be custom-made. You would also need to perform an azimuth alignment on the machine after replacing the head. It would be quicker, easier and cheaper to find another machine for this task, and keep the 5000 for recording work :(
Thanks for responding. The unit I believe has 4 heads, two appear to be larger and more metallic.
After further thought, this has a time track that is laid down the center of the tape, I was told. Therefore it has a separate head for that so in effect it has 3+1?
You might check with Randy Blevins at blevinsaudio.com. He typically has manuals for MCI and Sony.
Cheers,
Otto
Any chance you can photograph the heads?
I can take pictures, but I don't know how to post them. Owner's manual was found by the person I aquired it from will have it tomorrow.
Best to upload them to photobucket or something like that and post a link. It is possible to post pictures directly to the board as attachments, but they have to be less than 64k in size and for heads, we need as much detail as possible.
Yeah, I think your right. Too bad. It is almost new. I hope to find a way to use it. Thanks for your help.
I second that this looks to be an AWESOME machine!! I'd drool all over it if I got my hands on it for some nice mixdown work, maybe some live recording even!!
Using a machine like this for quarter-track consumer tapes is....hate to say.... a bit like giving children's books to a PhD professor who wants to read scholarly journals instead.
There are truckloads of quarter-track models on Ebay out there, some made by Sony. For best playback, you may want to figure out which machine was used to record the tapes, and use that to play them back too. Akai makes very nice sounding decks. I remember being thoroughly impressed with an Akai GX-747 that a co-worker had. It was quarter-track, maximum of 7.5 ips, but it had capability of using 7 inch and 10-inch reels.
Good luck with your endeavor.
I was going to say "like using a Ferrari as a pickup truck", but yeah...
Yeah, your right, too much for what I want to do. I went looking to find a replacement for 2 Akai's that don't work(one I bought in Japan in 1966), and a Sony that drags in rewind. I have a stack of tapes about 10 feet tall, and want to keep something to play them. I'll probably repair one of the Akais. This 5000 just fell into my lap, and I want to play with it for a while, then try to sell or something. I'm trying to gather up all the required cables so I can test it out. It requires XLR stuff. I got it recording, but the record volume is not enough. Do you think input is wrong impedance or something? It say it requires 10 ohms.
Well, it's good news, I fixed what was wrong with the ferrari. The pots that control the record volume were in need of cleaning. It had been sitting a long time. Got them working, and every thing sounds great. The owners manual is a great help, too. The manual is a binder about 2" thick. Everything looks new. Thanks for everyone's help.
