mark4man
MoonMix Studios
Tried this before, with limited response...so here we go again:
(& thanks to Jaymz & Teacher for takin' a shot at it):
Upgraded from SONAR XL 2.2 to SONAR 4 PE. After installation & opening v4, I noticed in Audio Options (ASIO) > Advanced Tab > File System...that my I/O Buffer Size had been automatically set to 128 KB, whereas it was always 64 KB in v2.2.
I then opened a project created in v2.2; & the playback was slow to start, with a slight (one second +) delay after hitting the play button (even after resetting the I/O Buffer Size back to 64 KB.) Went back into v2.2 & opened the same project; & playback started immediately.
The Buffer Size setting?...don't care about. I reset it. End of deal.
But the playback delay is bothering me. Other things bog the app down, as well. Normal functions such as scrolling in the Vertical Scrollbar too quickly, or moving the Outline Window in the Navigator Pane too quickly; & SONAR 4 goes a little fritzy. It also starts up weird...with certain elements & toolbars appearing as ghosts, before the main views kick in.
So what's boggin' it down? Is it API delay compensation? May be a factor in playback commencement.
But I think it's too heavy laden with graphical content...am I wrong?
I'm running a P4 2.53GHz CPU w/ 1024 MB of PC1066 RDRAM. I should be fine.
Thanks,
mark4man
BTW - Jaymz: Everything OK with you in Indonesia? Hell of a a thing...the tsunami!
Thanks,
mark4man
You need to check "Hardware Acceleration" for your graphic card. Display properties -->Setting-->Advanced-->Troubleshoot tab. It's usualy set to full by default. Reduce it step by step...
