SONAR vs. ADAT vs. Synth constant Battle
  • Thread starter Thread starter mojoasis
M
mojoasis
I've got a two part question. I'm used to Pro Audio and recently upgraded to Sonar. I'd like to use my Sonar 7 Prod. Ed. to create synth strings or drum tracks using my Roland XP-30 as a sound generator and record via ADAT XT20.
Part 1: I can't figure out how to get Sonar (or Pro Audio) to access any sound banks or patches on the keyboard (other than generic midi sounds when the XP-30 is set to general midi mode). What am I doing wrong?
Part 2: can I transfer the ADAT information direct to Sonar for editing without re-recordeing? I've got a Soundblaster Audigy (first series) with optics and firewire (never used). is there a better interface?
Should I abandon Sonar?
....a million other questions????
You need to connect the midi in and out and create a midi track, all the controls will be there.
No, the optical port on the sound card is an optical SPDIF, not ADAT. Audigy is a sound card for video games, not recording. You can get a EMU0404 for under $100 and that will greatly improve things. You will then connect the keyboards audio outputs to that.
No, it's good software and based on where you're at knowledge wise it is a good start. Read the manuals, do the examples, experiment until it all sinks in.
Thank you for the info on part 2. I'll look that direction.
As for part 1, I have MIDI connected and can scroll through the instruments using Sonar and pull the "general MIDI" patches off the synth just fine. It's the other patch banks that I can't access. I don't know if it's a setting on the XP-30 or in Sonar. Like I said, the 128 sounds found in "general MIDI" bank work like a champ. It's the other 1300 sounds I can't access using the Sonar MIDI controller. I can physically change the patch on the synth and hear the change on the midi track (not while playing or else I have to hit the panic buttons). Is there a way to get Sonar to pull off tracks from multiple patch banks? If so How? Can it do it with multiple banks simultaneously?
