SONAR LE MIDI tracks all have same instruments cant record separate ones..frustrating
John123
Equipment
SONAR :LE
Roland Juno Stage
Focusrite Saffire 6USB
Hello all hope you can help. I am trying to record different midi tracks with different sounds/instruments. My problem is that whenever I create a new midi track and try and play over track 1 (elec guitar) with a bass on track 2 the sounds both change to the bass. I am using the sounds straight from the Juno so when i change patches on the juno to a bass everything changes in the project to a bass. I have had a look at what channels they are transmitting on and think this may be the problem. I know this might seem easy to work out but having difficulty with. Any more info please ask. Not sure if the attached file is visible.
Thanks guys
Is your Juno a multitimbral synth? If it's not then what you're trying to do will not work.
Try using soft synths instead
