EddieRay
I'm in a fix. I bought some gear off Craig' s list that included Sonar HS 4.0 and tried to install it. I already have Cakewalk 9 which was installed over Cakewalk 7 a long time ago. Somehow the 9 and 7 directories and files got intermingled, maybe by design, but I did not want SONAR files mingled so I aborted the initial install and tried again only this time putting SONAR in it's own directory.
The final task (I think) was "updating system configuration", which seem to hang up. I waited about an hour and then tried to see the Windows XP Task Mgr but no good. I tried a warm boot but no good either. So I powered down.
SONAR is installed but it doesn't see my Aark24 card and it thinks my SB512 has 1 input and 3 outputs.
So i figured I'd uninstall but the install log only shows the aborted install so neither Windows Remove Program nor SONAR uninstall will work. Farts.
I'm not sure what to do now: manually delete SONAR directories, or see if the system restore can bail me out, or just attempt a reinstall over it and hope for the best.
Whaddya think? I'm leary of making a move without any advice because I'm apparently too damn smart for my own good and I'm sure I have not exhausted the possible ways I can screw things up.
Addendum: the initial install was aborted before anything was actually installed. Only the install log was created.
