C
clivewil
normally i used to use Sonar 2.2 with plain ordinary old Midi Clock, but recently tried to get it running with MMC/MTC instead as this is what my Yamaha DAWs sync to, they won't use ordinary clock
Sonar 2 craps itself pretty much instantly whenever i use MTC/MMC instead of clock. the best i ever got was a single pass from the song start; it never once succeeded synching from partway through. if it dies, i get a hung SONAR.exe process in the task manager which i have to close manually. midi buffers are already maxed and aftertouch etc. is turned off.
ok, same gear, same setup (i'm even using the same sequence, converted) - tried Cubase, it works fine no problems. after an iffy start, it even manages to sync itself if i start the song partway through. never fails, works every time. terrible gui though.
my Sonar is too old perhaps? so i try a newer Producer Edition - it craps itself instantly in exactly the same way as my own Sonar 2.2 does.
i notice there's nobody else having this problem so i hope there's an easy solution - Cubase was very fugly and clunky, and i'd rather stay with Sonar. any ideas?
