J
jkakos1104
Hey,
I posted this on the Cakewalk Forum but still is pending so I thought I'd throw this Q in here to see who can solve. Here's the issue...
PROBLEM - When playing back recorded audio (whether it's guitar or bass) the timing is off with the MIDI drums (Session Drummer).
The timing is either off right at the start of the song OR it stays in rhythm but tapers off toward the end. For example, if I do a quick 1-2 minute song, usually there's no problem; if it's 3-4 minutes I have to split clips and go into the Clip Properties to change the START time so it plays in synch with the midi drums (Session Drummer).
I've changed the Playback/Record buffer sizes from 64 to 128 to 256 but it doesn't seem to work. I've also updated the drivers for the Lambda sound card (which I assume is not highly recommended for Sonar).
I'm wasting a lot of time messin' with audio clips.
Appreciate anybody's help.
HP Pavilion DV4
O/S - Vista (unfortunately)
Processor - AMD Turion 2.1 Ghz
4G Memory (64-bit)
Sonar 8.5 Producer
Sound Card - Lexicon Lambda
HP Pavilion DV4
4G Memory (64-bit)
Sonar 8.5 Producer
