A
Alan McGuinness
Running sonar 6 producer on winxp
Line6 Gearbox
I am getting audio glitches on playback but when i try to increase the buffer size in the audio options-advanced tab, say from its current 128 to 512 and click the ok button it does not change to the next options tab, as it would with any changes made elsewhere in the options tabs
If I then close and reopen the audio option dialog box its back to 128. Same situation if I try to change driver mode from WDM/KS to ASIO in fact the heading on top of the audio options box is "audio options WDM/KS" which makes me wonder if I have the ASIO drivers or not. I know I have the most up to date drivers from Line 6 via download so now I am confussed.
I was running sonar 4 producer and did a full uninstal before installing version 6, I also uninstalled and reinstalled gearbox for good measure. In version 4 I was using ASIO drivers and had no latency issues
Any thoughts would be greatly appreciated
Alan.
Line6 Gearbox
Alan.
