Sonar 5 and Kontakt... Apparently too much...
  • Thread starter Thread starter neon glow
N
neon glow
Since upgrade to Sonar 5, Kontakt 2, having only Steinway Piano loaded, uses 70-90% cpu, causing sound to click, and break. I'm on AMD64 3000, 2gigs ram. Why such overload?
Does the same thing happen if you DON'T use the 64-bit double precision engine?
If not, then you are just seeing the additional overhead of doubling the length of each and every calculation.
Q.
Interestingly, 64bit double precision is off. Besides, the cpu usage isn't doubled. I think it's quadrupled since Sonar 4.
