Sonar 3 problem
  • Thread starter Thread starter theForgotten
T
theForgotten
Hi there!
I have a problem with my Sonar 3 Producer Edition.I import midi and with Steinberg Groove Agent when I export KICK to *.wav first notes are normal and other are not loud as the first few kicks.How can I fix this problem.Thanks!
so its loud when you are playing it back, but it attenuates while you are converting it to audio (via VST).
Could it be that the first notes are doubled (as in two MIDI-kicks playing almost at the same time)?
Are you muting the MIDI track after you render it to audio?
If not, that could make it sound pretyy washed out -- they'll be some phasing going on...
First i make whole song in midi for example in Guitar Pro 4 channel by channel,kick on the first channel,snare on the second,toms on the third,etc.I export from Guitar Pro 4 in midi and the import the song in sonar.For bass,strings i use Edirol and for making drums i use Groove Agent.When i play drums in sonar are ok but when i export only kick is first couple of notes normaly loud and after is quiet and all drum components are ok.Btw thanks for the posts!
