sonar 2.2xl with delta 66
  • Thread starter Thread starter theodore02882
T
theodore02882
Hi - Will Sonar work with M audio omni studio w/delta 66 card? I'm running XP, and the card has ASIO drivers. Thanks
Yes, it will run perfectly!
But you might want to use the cards WDM-drivers since Sonar originally was a WDM-based program (although after the 2.2 update you can use ASIO-drivers with Sonar without any problems at all). :)
No problem! :)
(and a little disclaimer: It will run perfectly if your computer is up to the job, of course... ;))
