Someone tell me about their resonator
  • Thread starter Thread starter Nightfire
Nightfire
Nightfire
Aspiring Idiot
How do you guys play these things????? Can you strum them like a regular guitar? My friend has an old all-steel resonator and strumming it just gives a pretty dead sound, doenst ring like an acoustic. Are these for slide only?
Anyone have samples of yours etc.
Mike
Well, it used to be a paper clip, but I crafted it into a shape that gets most of the resin out of my pipes! :)
BACK TO THE CAVE NOW!!!!!!!
Mike
As long as you are talking about a round neck resonator-yes you can play it and fret it like a standard acoustic guitar.:cool:
A square neck is for slide only and usually has a very high action-due to a raised nut-so you can't fret notes properly on a squareneck if you tried.:eek:
I use a Regal with a spider bridge all the time with my bluegrass band, the tone is more metallic than a dreadnaught-but the volume is great for lead breaks.:)
The metal bodied dobros just don't any woody acoustic tones at all-I've played a few and they just didn't suit my playing at all~:(
I have a silly country tune called Stone Krazy improved mix???? on my soundclick site that you can hear my Regal played on the choruses-don't worry-its only about a 2:30 minute song, so its over pretty fast!
Resonator guitars were originally developed so that guitar players could compete with the horns in big bands in terms of volume. They were quite successful in the days before amplification. they were always played like regular guitars in those days. Their use for slide came later. A resonator guitar in good playing condition is quite loud. They may or may not have good sustain.
If you could describe the sound of your resonator guitar as dull there is something wrong with it. Have a luthier check it out. You may or may not like the sound of a resonator guitar but it certainly shouldn't be boring.
A very brief primer:
Besides the two kinds of necks there are also three different resonator configurations each with own unique sound. These are commonly referred to as: National, Dobro, and tricone.
The National type has a cone (like an aluminum speaker cone) with it's center pointing upwards toward the face of the guitar. A disk of wood rests in the center holding the saddle. They have a bright sound and a crisp attack. This is the configuration most popular for bottleneck slide playing. Most of these were made with round necks, however square necks were made also.
The Dobro type has a cone that is folded in the middle so that only the center part of it points toward the face of the guitar.The bridge is a frame that suspends the saddle above the tip of the cone. There is an adjustable screw that connects the cone to the saddle. These have a warmer gound with good sustain. This is the configuration most favored by bluegrass players. These guitars are more likely to have a square neck. although round necks are not uncommon.
The tricone uses three much smaller cones of the National configuration. These are the brightest of the three configurations. Both neck types were used.
There is a lot of info on the web
Put on new strings if you haven't. Make sure the bridge coupling mechanism to the resonator is intact and set up right.
Thanks a lot for the info. Im gonna try some out at a music shop this weekend.
And Anfontan, I dig the song:D
Mike
Mike
Thanks for the compliment, its the first I've written as far as a country tune. Actually the song No Time-Remix also has some resonator bits in it as well-and quite a bit of mandolin too.
